New Chap
T786
Hi peeps,
signed up today i have a 2005 55 T2 2.0 d4d & a 2006 56 T4 2.2 d4d both are hatchbacks,
i could do with some advise re: gearbox on the 2005 55 T2 2.0 d4d 5 speed i was to have the clutch & flywheel changed and the mechanic noticed that the gearbox shaft is excessively worn my options are 1#,to have the gearbox reconditioned or 2#,to find a low milage geaerbox, if i don't go with 1# & 2# is hard to find then can anyone tell me does any other Toyota 2.0 d4d ie: Auris or Corolla share the same type gearbox that are/will be a direct fit? also can anyone tell me were the gearbox code can be found? there is a sticker on the gearbox but was faded all i could make out was F8 in the top LH corner.
any advise or help much appreciated cheers.
Welcome to the club, drop a PM to PartsKing and he will be able to advise you :thumbsup:
Welcome to the club, hopefully Parts king will be able to help you :thumbsup:
thanks for the welcome, i have sourced a box its been fitted as i type away just hope its a good one, i will pm/contact Parts king if i dont get anywhere with the replacement.
cheers.
On the bottom of the VIN plate you will see the bottom line look something like
C/TR/A/TM it means, colour, trim, axle, transmission, what you are looking for is something like EA62, EA63, EA65 etc
Kingo :thumbsup:
Kingo :thumbsup:
thanks m8 thats a good bit of info, car has been up and running since my last post but need to fit a new clutch master cylinder as the knuckle has worn and my local toyota dealer says it all comes as a complete unit.
