Rav 4 Diesel 5Th Gear Vibration
peterloud
Hello all
Last month I bought a second hand Rav 4 d4d gx (2003/04) diesel with 80,000 miles with full Toyota service history from new and noticed when driving home that when in 5th gear, and only 5th gear, there is a vibration through the gear lever.
It's a bit annoying!
Si I plugged in that in to Google and came here and found this idea here http://www.toyotaownersclub.com/forums/index.php?showtopic=104794
and when I read that I was very pleased so went about taking the gear knob off and dismantling the centre console which was a bit of a mare, put a rubber spacer on the right hand gear change rod, put it all back together and took the car for a road test.
Well, the gear lever still vibrates , a bit less i would say for sure, but still vibrates!
Any one else had this? It could be a syncro but does seem odd and am reluctant to go to Toyota because they may well say needs a new gear box or something which will be expensive
car runs fine in 4th
Help!
Peter
Yes, I seem to get it in other gears too if the engine is under load. Stops as soon as I touch the gear level. It's annoying but for now I just put the radio on to hide it. I assumed either the previous owner had rested their hand on the lever when driving and damaged the box, or as a design flaw the lever just sits too close to the trim somewhere. The trim may also have been refitted badly after a telephone car kit was removed. Might do as you have with the rubber one day but it's started getting super cold here so not just yet...
Do please post back if you find anything else.
Hello all
Help!
Peter
I have an 04 petrol rav with same problem, mentioned it to Toyota when it was in for service, they said could'nt hear anything. On service report they said gearbox had a wine and recommended strip and inspection......no thanks, I will turn up radio. only 50k on clock
Peter
