Engine Vibrations At 2400-2600 Rpm
revpete
My 2002 Avensis 1.8 VVTI engine vibrates quite badly between 2400 and 2600 rpm. It vibrates in this range when in neutral and in every gear as I accelerate. The engine is completely smooth before and above this rev range. Any suggetions appreciated.
  • 8 years later...
Hello revpete,
did you able to find what was the problem with your vibration issue?
