Navi Tns310
kristapovich
Hello everyone.
I have a Toyota Avensis D4D year 2006. I have the TNS 310 (Traffic) Plus Toyota DVD Navigation System, with very small screen 
I get this care used from Belgium.
So I am interested where is located the disc for this system and how I could activated this system.
When I push button NAVI on screen shows some text in French language and when I push different buttons, nothing is change. Is there possible to change the language on English.
How I could operated with this Navi system, I have Manual, but from the manual I don’t understand where is located the disc.
Car has car audio system with six CD MP3 disc changer.
Hi
The navigation is usually located underneath the front passenger seat if you slide the slider on the front of the unit it should eject the disc if there is one.
Hope this helps
THurn
Hello everyone.
How I could operated with this Navi system, I have Manual, but from the manual I don't understand where is located the disc.
Hello, as Thurn says the DVD drive is under the passenger seat and yes you can choose language from a menu, maybe if you eject the DVD disc and then put it back in it may default to English but I am only guessing here, It is possible that the disc is missing and that is what the message in French says, copy the message to here and we will try and translate it for you.:thumbsup:.
Regards Pete.
Hi, I had the same problem mate. Decided to have a look under the pasenger seat!!! Should be a DVD player there.....Insert the DVD. All should be fine. :-)
Thank you all :)
I finaly found the location of disc. It was under the drivers seat, also i change the language on English :toast:
Thank you wery much!
