Avensis 2001 'chirrups' When Cold
captain beserk
Hi Gang!
I love my old Avensis Estate (1.8 vvti petrol) 150k miles... Runs great but
has started to make a high pitched chirrrping noise when cold. I thought this might be
the ancillary belts being a bit worn...or is it the water pump starting to go? Or is it something
completely different? Any ideas greatly appreciated. It doesn't use oil and has been well serviced
by toyota.
Cheers
Captain Beserk
post-87760-090546000 1288025276_thumb.jp
Hi Gang!
by toyota.
Cheers
Captain Beserk
hello captain
it would be better to hear this noise, that is in question.
the easiest way is to open the bonet and start the engine and listen carefully. i am inclined that the belt could be an issue due to to be adjusted.
Chers/Igor
:thumbsup:Thanks Igor! had a proper listen and the noise is coming
from the belt tensioner...and the belt looks a bit glazed
so I will get and fit a new one soon. While I'm at it I'll
check the tensioner bearing too
Happy Toyotaing!
Captain Beserk :thumbsup:
Happy Toyotaing!
Captain
AS far as I remember -- both are subject to change simultaneously - you ll kill this issue on the root.
Good luck/Igor
