99 Avensis Key
allred
Hi ! Got 1999 Avensis , but only one key. Seem to get lost following links to key websites and end up nowhere. Anyone got sound advice??
I wish you well in your search for a reasonably priced key, although I think I will cost to have it programmed. Main dealer charge is £200 plus.
In your case I would go for a working second hand key with remote :
http://global.ebay.com/TOYOTA_2_BUTTON_REMOTE_TRANSPONDER/120635281442/item
And a key casing with an uncut blade and button holes :
http://global.ebay.com/2_BUTTONS_REMOTE_KEY_CASE_for_TOYOTA_COROLLA_RAV4_CAMRY/160495967367/item
Get the blade cut, and assemble the parts, before programming it to your car.
Yet again, I have not tried this myself, but it may be worth a go.
Thanks Gooli. I,ll let you know how I get on.
Don't know about locksmiths, but i guess they can provide both
the uncut blade itself, as well as the cutting of it.
That way you would only need to order the used key with remote.
Also check if your key is Denso or Valeo type, to get the correct one.
