just fitted a cat back on my glanza and started hitting fuel cut, i am unsure whether to get a boost controller and turn the boost down or a fuel cut defender . i am a bit of a novice with turbo charged cars (first one) will it be safe to fit a fcd i dont wanna blow my engine
The big mistake most people make is that they just stick a FCD on without altering anything else and end up with detonation
You need to make sure you up the fueling and the air getting into the engine to make sure it runs as it should.
If you get a HKS adjustable actuator it will be able to hold the boost a lot better
  • Topics
  • Our picks
        • Like
        • Like
        • Thanks
        • Like
