Ecotek Power Boost Spay
knowlson
Just brought a can of this stuff going to try it out at the weekend anyone used it on there car yet??
Yep, put it thru the inlet manifold of my Golf.....................................Nothing! and it cost about £20. I'd be interested to know the results for your car when you get them.
My apols, it's the '10K Boost' I used. The problem with these product is, they clean all the crap from your cylinders etc but where does it all go, not out the exhaust, thats for sure. Down into the bottom end is where it all goes, an that cant be good!
Banzai did a test on it last month on a 200sx they did a dyno before and after it showed that it can work :thumbsup:
Worked on mine by reducing the emissions,picks up better in the lower gears and got about 5mpg better.
Changed my oil and filter after about a week of using it and all ok
