Engine Swop ?
jokiemay
Ive a 93 gen5 st182 celica and its leaking oil from Head gasket
somebody i know id selling a 3gse from a 96 gen 6 celica.
will the engine fit? will the ecu work with it ?
is there much difference?
If they are both 3sge engines, then the wiring loom should be pretty much the same? Check the ecu to see if they compare??
