Knocking From Rear End
jimtaxi
Hi All I have a knocking noise from the rear axle area when going over a few bumps in quick succession there is a distinct knocking noise.On smooth roads like motorway etc no noise, it makes no difference whether I have passengers on board or not.Any clues as to which component is worn.The car is an Avensis 2.2 T3X hatch.
Could be a nuber of possibilities such as worn shocker or anti-roll bar bushes. You'll not really know until it has been closely examined.:)
Problem solved both roll bar links were shot common fault due to speed bumps now. £102.00 including parts. !!
