T180 Problem?
Roadwrangler
I've only had the car 9 days, was hoping to go a bit longer before anything started acting up. The car started fine at 6.30am this morning, when I left work, leaving work around mid-day it was starting and then dying straight away, did it probably half a dozen times, in the end I used both feet, one in the throttle to hold it open a bit, the other on the clutch, hit the start button and it started, I had to play the throttle a bit to hold a fast idle for 20 seconds or so and then it idled ok on its own and I drove home, no warning lights on. Had to use it again this evening around 6.30'ish, it took 3 presses of start button before it would idle without dying. Its started first press of the button every time untill mid-day today. Anyone got any ideas?
Regards Austin..
Austin.
If it runs OK when warm it could well be the glow plugs which can play up. They are dead easy to test with the bus bar off and I can find you some values for your ohmeter.
Austin.
That would be great thanks.
