Locking Wheel Nut Removal
jtmk
I am hoping someone can help. Some ***** at the tyre shop has used an air ratchet on my front tyres when changing them and my front nearside locking wheel nut is totally burred. To make matters worse I am now hearing a squeal from that side when braking. The locking nut has a spinning collar on it so I cannot just bang on a socket over the top. Can anyone give me a suggestion how to get this locking nut off?
The chap who does my mechanics has a set of special sockets that grab the locking wheel nuts. It destroys them, but at least they are off. I had the same problem as you with my wheels nuts, and ended up buying a new set.
Have you tried taking it back to the tyre shop in question or is the tyre flat??
Pete.
The garage is about 130 miles away as I got the tyres done when I was visiting my parents in Kent. I have a squeeling brake on the wheel concerned so don't want to risk driving back.
What type of chisel and hammer did you use to break the outer collar?
