Avensis Diesel Hard To Start When Cold
bandit2010
i have a 00 Toyota Avensis TD 2lt that has been getting very hard to start when cold. Have done all the usual checked heater plugs all working Battery good turning well have been told that the valve collets need to be redone any suggestions?
i have a 00 Toyota Avensis TD 2lt that has been getting very hard to start when cold. Have done all the usual checked heater plugs all working battery good turning well have been told that the valve collets need to be redone any suggestions?
Hi Bandit,
I have a 2.2 Auris D4D which has displayed your symptoms for a while now, it never fails to start but it just chugs and chugs before it does.
Toyota have had my car for more than 2 weeks in an attempt to solve it back in March this year, in doing so they have changed my Battery and EGR solenoid/valve but all to no avail.
I have done the DIY EGR clean since but this does not help this issue.
There are other variables such as injectors and starter motors that could be at fault, but at the moment i am just keeping my fingers crossed... which is not ideal.
hi mate
-at what outside temperature you were trying to start?
-where do you normally get diesel?
-whether both SCVs are in order?
-what bout fuel injectors?
cheers/Igor
