I have fitted a K&N Induction Kit and have been told that some people take the ECU fuse out when installing the kit, I didn't! :angry: Can I reset the ECU after, as the kit is already fitted, if so where is it and how should I do it? Thanks
Oh and I have a UK 1990 GT T-Bar :thumbsup:
It should be in the fuse box in the engine bay, its lablled ECU (strangely enough), I think some people also take out the ignition fuse aswell. Wait a couple of minutes until you put the fuse back and then job done :thumbsup:
No need to remove ignition fuse. Just the ECU fuse. Some people advise tapping the brake pedal to drain all power, though personally I can't see how that could have an effect (unless you're taking the disconnect the Battery route). I find removal of the fuse in the engine bay does the trick :).
Cheers guys :thumbsup: Will try this later when I get in. Should I notice anything different when i've done it? :huh:
Have a look in the "Guides & How too's" at the top ..
your car will probably run like poo for about 15 mins (lumpy idle and all that - near stalling at lights).
drive it in a variety of ways for 15 mins ie fast, slow, gentle roads, lots of cornering, and this will help reset your ecu :thumbsup:
Am I right in thinking this should work for any Toyota, not just the 2?
:lol: I drive like that normally dj_davo!!! :crutchy:
It should work in anything with an EFI system that learns and stores settings in memory backed up by power.
