Wax Removal
micky777
Hi all
Can anyone explain why you have to remove wax prior to
fitting door protectors etc,also what is the best thing to get the wax off
cheers for any help......
Hi all
Removal of wax/polish is to allow the adhesive tape to bond directly with the painted surface. If the wax is left it forms a barrier and the trims will peel off as the wax breaks down.
I believe body shops use Isopropyl alchohol [Auto factors sell it I think]
Personally I use white spirit on a clean soft cloth.
DO NOT use cellulose thinners as it will dissolve the paint surface :eek:
I use lighter fuel.. you can also use a little petrol, but be carefull.
Would T Cut do it ?
'T' cut is quite abrasive - it will remove the surface layer.
Not recommended and the residue would still need to be removed by the isopropyl alchohol or white spirit etc.
Hi all
My favourite tipple for this kind of job is Panel Cleaner. I get it in 1 litre cans from my local car bodyshop supplies outlet. It removes wax AND silicone ( far more difficult ).
Hi all
Pretty sure Panel cleaner is 50% IPA [not the Greene King kind :rolleyes: ] Printers use it by the bucket load :thumbsup:
Hi all
My Chemist pal said he thought it was a weak acid in a solvent which ties in with your own thoughts about IPA. Another bit of random information to clog up the hard disk between my ears :blink:
Hi all
Yup, we're on the same wavelength on this one I think Chris.
One thing to consider is that it's really good at taking off grease and residues but it evapourates quickly and thus leaves you a greasy cloth pretty quickly so you need to keep turning a new cloth face to the surface being cleaned or you end up smearing the contaminents back on again.
Hi all
I knew a guy who favoured panel cleaner - he's dead now. Burnt his stomach up. :crybaby:
IPA also evaporates completely leaving no residue ( as does Panel Wipe ) - always handy not to have to clean the gunk up afterwards
If you're struggling to buy IPA solution send me your address by PM and I will stick a small bottle in the post to you :thumbsup:
Add APC or small drop of fairy liquid into your wash bucket. clay could also be used or a mixture of both
Blue
