Hi, I have a problem with the car antenna.. It just don´t **** to rise... I have a pionner P6550, the motor of the antenna seems fine, but apparently the radio does not send the signal to rise up the antenna... Can I make a button to manualy rise the antenna or something like that???
Yep that shouldn't be a problem. You just has to connect the signal input wire (for the aerial) to +12v (ish) and it should rise.
thanks!
