Strange Noise
richard price
Hi - On turning off the ignition I get a 2 second rushing noise with a slight screech that I am sure is from the Speakers it happenes if the engine has been running or you just turn the ignition off without starting the engine, the radio can either be off or on it happens. All electrics are woring fine and there is no difference in the way it drives. Any body had a similar problem??. Thank you. :unsure:
Make sure the heater is switched right off and try again :thumbsup:
I get the same with a Renault Midlum. A thump on the radio fixes it!
Tried that yesterd after a 20 mile run to work, it made no difference, so I tried a number of combinations ie leaving things on and turning off, again no difference. After the return journey home it did not make a noise, spookey. C what happens today. :drool:
Hi - Its started to make the noise again. Any more ideas please. :help:
The aircon makes some funny noises when it shuts down. Are you sure it isn't that? Try to record it and give us a sound clip. Is your recirculation button pressed. Also, the headlights sometimes cycle through the height adjustment when you switch the ignition off.
Anchorman - Thank you I will get the computer literate to sort that one hopefully this weekend. :thumbsup:
I get something vaguely similar but its to do with the intercooler pump and cooling fans trying to cool down the number 1 beast after a good run.
