2002 Yaris D-4D Will Not Start
QAS
Hi Guys
I haven't been here in a while. Today i was driving the Yaris and all seemed fine until i stopped at tesco for bit of shopping. When i tried to start the car it would't start, engine turns fine but there is no ignition.
It's a 2002 D-4d and has been running perfectly till today. It seems like a immobiliser issue but i cannot be sure. Engine just turns and turns but no ignition.
Any suggestions or checks i could carry out?
Your help is really appreciated.
Kind regards
Hi Guys
Kind regards
Battery is more than likely your issue it is either flat or[What a sad muppet I am thinking I can overide the swear filter] try jumpstarting it and see if it starts. If that fail and i bet it works it will be your starter motor is either jammed ( try push starting her ) or[What a sad muppet I am thinking I can overide the swear filter] and needs replacing. :)
Hi
Thanks for reply. I tried jump start and push start but still nothing. Engine turns but not starting. Could this be to do with the key?
Hi Guys
Kind regards
If the starter motor turns over normally, it's probably not electrical.
Does it even try to start or nothing at all?
If it stutters but ultimately fails, could be fuel pump, blockage in the fuel line/injectors (debris? cold?) or maybe you didn't have that much fuel and are parked on an incline?
If it doesn't even try to start and you only get the starter, I'd lean more toward immobilizer or fuel pump failure.
Only starter is turning, engine won't fire. It was running fine before only when it was parked for few minutes then it wouldn't fire up at all. Starter is turning the engine fine. I think it could be imobiliser or fuel pump but would they just fail like that all of a sudden? I haven't had any issues with this car before.
I see you have a Power Box.
Try disconnecting it to start with and recoonect direct to fuel rail.
Does the fuel pump start to whine when you switch on?
Any warning lights?
Hi Guys
Kind regards
hi mate
if all was fine before - ok check with SCV mounted on the pump -- it looks like they play with you due to either coils lissue or an electricity lose. Cheers/Igor
