Air Con Issue
ditmb
I have a 2006 LC5 and just today the air condiotioning seeems to be acting up.
When it is set to max cold the drivers side and the rear of the vehicle are ice cold.
The front passenger side is not cold but the temp of the outside air.
If I close all the vents in the car the passenger side does get colder but not as cold as the other vents.
The heating part works fine.
I have checked the filters, the pipes, the compressor and they all check out OK
Now at a loss at what to do next, any help/advice much appreciated.
hi mate
it looks like the fan is twin type mounted on the same horizontal shaft. the possible reason that the left fan lives by own life due to link losing between shaft and fan itself. The evaporator is only one and it is in order as driver/rear sides are cooled. Cheers/Igor
  • Topics
  • Our picks
        • Like
        • Thanks
        • Like
