Indicator Lense
thatch
Hi guys, does anyone know how to remove the front indicator from a 20002 avensis? Do you have to remove headlight as well? It is all steamed up and i want to take it out to dry and seal it. Thanks...
It's so simple, you won't believe me.
If you look at the top corner where the main light unit meets the indicator unit, there is a space or hole if you like. insert a screwdriver & press down on the plastic clip, but not too hard. As you do that pull out the indicator unit & it will easily come out. remove the lead & there you go. Reverse it to put it back in.
Personally you can buy a new replacement off eBay for £12. I just fitted one to a friends car & it fitted 100%. Link below
http://cgi.ebay.co.uk/TOYOTA-AVENSIS-00-03-FRONT-INDICATOR-CLEAR-BRAND-NEW-/150513737208?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item230b515df8
Cheers,
Marv
