Rear Door "card" Removal.
mrpj
Does anyone know if there are any hidden securing screws on a 2010 TR Yaris rear door interior panel?
The only two visible are the screw behind the internal door pull under a plastic cover and the screw on the door handle assembly are there any others?
I know on the front door panel the grey trim needs removing to access screws behind, does the same apply on the rear?
Thanks in advance. I've done a search and found nothing relevant.
