How Do You Remove The Rear Tail Light
kennz
hi guys,
i need some help on how to remove their rear tail light off the car, i am not able to locate the screws that is screw into them not too sure how they are screwed in, any help would be appreciated
thanks
Ken
  • 4 weeks later...
Hello,
If you try to replace the tail light bulb, you need to remove the plastic cover in the back, Pull the small red clamp inwards a little and then pull out the white plastic support towards the front of the car.
hope this helps.
