Radio Reception
kimbo23
Can someone tell me where the radio aerial is on my car? I have a 2003 Avensis T3X (2.0 vvti).
I seem to be getting very weak radio reception in my car.
If its the same as my car (05 T3 estate) then the arial is in the rear drivers side quaterlight window. Looks like a heated Window element.
Regards
Hi mate, all you need to know is in the .pdf document which can be opened with the free Abobe acrobat reader software, the very last parts shows you how to repair a broken window aerial.
Hope this helps, regards .... Pete.
AUDIO & VISUAL SYSTEM.pdf
ah ok its one of them sorts. I thought it would be a pull out aerial like on the older avensis models which you can extend by pulling out.
Not sure why my radio reception is that weak. ill have a propa scoot around after work maybe (if its not too dark)
