Ok i'm stuck.. I've removed all the smaller dashbaord panels and the glove box, but how do i take the main part of the dashboard out? I've removed all the visable bolts and screws that appear to attach the dash to the car, but are there any hidden bolts or screws under the dash? :huh:
Help please!
'93 G-Limited
Taking the dash out is a right pain of a job I had to do it when I replaced the heater matrix.
You will need to take out the stereo and all the screws in it. Then when ou have taken all the screws out pop of the small section under the wheel if all the screws are out it will pop of, now if a remember the rest will pop of you will have to move the cd rack you will need to pull out the gater for the gear stick you dont have to remove the rack but you need the room when pulling the dash out.
I have a mr2 manual on disk and will try to post some pages out of it.
