Keeping A Car For The Long Long Term
I know this is the classic section and a 99 Corolla is not a classic
However i was hoping that maybe someone into their classics might be able to answer a few questions i have.
Thing is i really like this car - its completely irrational i know but there really aren't any other cars id rather have instead.
Strange as it may seem - seeing as its a normally aspirated 2.0 diesel i really love driving it. Because i like older japanese cars and
enjoy driving diesels - im thinking of keeping this car on the road for as long as possible
So if a car was to be kept for as long as possible - whats the best way of checking that there isn't corrosion hiding underneath
underseal.
Whats the best way of protecting the body from rust in the future, and finally is it possible to keep driving a car
like this all year round with top class maintenance - and keep it on the road indefinitley (suspect the answer is no but no harm
asking anyway).
Thanks for the help
Red diesel
To check corrosion under the underseal, the only proper way is to remove the underseal and inspect. After removing underseal, waxoyl your car every year preferably in the warmer climate. This will keep rust at bay.
Thanks very much - i suspected that this would indeed be the case - whats the best way of removing the underseal
Thank you
Red diesel
Thank you
Red diesel
Sadly this job is not easy and always filthy unless you can afford to get it professionally blasted off preferrably by soda or beads :huh:
Otherwise you will have to wait until the warmer dry weather, probably warm the underseal with a heatgun and then soften it with petrol and scrape it off. This must only be done in a very well ventilated garage.
This task is awful, smelly and very very dirty. Sadly there is no other DIY method that I can think of :ffs:
However, you can simply scrape off any loose underseal and spray the rest with Waxoyl which will soften and soak into the underseal that is left in place. If you dilute the waxoyl with plenty of white spirit before spraying then it will work nicely :yes:
Red Diesel,
I also have a 90's model Corolla, mine is a 93. The best way I've found to protect the body is simply to keep a layer of wax on it at all times. It's worth the extra effort in my opinion. Just like you, I don't want to get rid of mine. It's paid for, reliable, and gets great milage!
Eric, in California
