Replacement Of Low Beam Bulb
Oxon Blue
My 2004 2.0 D4-D T3S Tourer has a blown O/S/F low (dip) beam bulb and I want to replace it myself. However, I cannot seem to locate the H7 bulb socket at the back of the headlight. I have located the H1 high (main) beam and the sidellight bulb socket, but even after searching several times I have failed to find this bulb. Is it hidden inside the indicator bulb housing or something? If so, how do I get to it?
I previously had a 2000 Avensis 1.8 GS VVTI and the main and dip beam bulb were one and the same, but it appears that this has now changed and there are 2 bulbs. Any help on how to locate this dip beam bulb is gratefully received.
The headlight looks like in the attachment.
How to get at the bulbs may, depending on the model and trim, ... be challenging. :unsure:
post-84513-032918800 1291970310_thumb.pn
post-84513-026500400 1291970332_thumb.pn
Many thanks Thermal, I'll take another look at the situation. However, if anyone else on the Forum has any advice then please do contribute.
