Dmf Conversion Kit
nig.xl
I bought a kit from Euro, supposedly to fit my Rav, but the box is marked up as fitting a Ford Transit or Mondeo TDCI engine.
When I queried it with Euro they said the parts were the same :unsure:
Anyone had a similar experience before the car is stripped and left stranded on ramps ?
I can't answer that question. I must admit it sounds suspect but who know's - maybe???
I cannot answer it either, but having just had a DMF kit fitted to my Transit engined cab, I find it hard to believe that it shares the same DMF as your RAV :unsure: I would definitely check out both part numbers, but as Anchs says - maybe??? manufacturers do share parts these days, But TOYOTA + Ford, I hope not :o Stew
Looks like I may have to check with local motor factors in the morning. I would also be very surprised if Ford and Toyota share the same smf kits, soon find out !!
Just to report back, the SMF conversion went on fine. I was told to take no notice of what it says on the box by Euro.
Car drives superbly now, no judders in any gears :thumbsup: Looks like I managed to catch it early.
not sure what was in your kit.but as luc make most DMF and indeed invented them, if its a mod without flywheeel renewal then the kit should fit a wide range of cars.
glad your pleased with mod and it must give + you peace of mind.
