Engine Oil Recommendation Tech Heads
AURISTR01
Is it okay to use 10w40 rather than 5w-30?
Has anybody had any issues with the DIESEL PARTICULATE FILTER.
I accidentally put in 5w-30 recommended for the 505.01 VAG engines but it was just a top up maybe half a litre, would this cause any damage? Considering the engine takes 6.5 litres it will probably just mix with the original oil.
Please reply Thank you
I think 5W 30 is recommended oil. I can't see an issue with 5W 30 from VW as their specifications are quite strict and you can see them on Toyta suitable oils..
