Fuses Map For Avensis D4D 2007
geaniuk
I have a problem with tail fog light.changed the bulb but still didnt work,and now the indicator on board stopped working as well.i want to try changing the corespondent fuse but dont know witch one is.so if someone can help me with an advice pls do so.
tks
tks
The fuse is a 10 amp, number 43 in the fuse box behind the glove box. However it also serves parking, tail, licence plate, boot light and fog so unless they are all off the fault will not be the fuse.
Fitter
