Hi
Could anyone help me identify the window washer fuse as my manual doesn't have it listed.
Oddly it does have the wipers listed twice.
Is the fuse in the engine bay ( please let it be under bonnet ) or in the ( A pain to get at ) under steering wheel one.
What's the exact problem you;re suffering from? I ask because according
to my documentation the wipers and washers are on the same fuses.
Main power comes from the 3rd one from the top on the lefthand side
of the instrument cluster. It's a 20A fuse, so it will be yellow in color.
Several of the electronics and relays are powered by a second fuse,
this one is on the 3rd position from the BOTTOM, also lefthand side.
It's 7,5A, which is brown from the top of my head.
This second furse also feeds controllers for the power windows, ABS,
backup light, central doorlocks and remote, rear defog, Power Steering,
A/C, rev counter, heater and the cooling fan for the engine.
Hope this helps,
