Sr 180 Electric Window Malfunction
Paul Mack
Hi Guys,
its been a while since I have been chatting to you.
I have an issue with the electric window on my drivers side ie it no longer goes up automatically.
I seem to recall that you guys had a solution for this on an old thread.
If anyone can help me resolve the issue, I would appreciate it.
Thanks and Best wishes to you all for Christmas and the New Year
Paul :thumbsup:
Paul Mack
Do you mean the "one touch" isn't working but it's OK if you hold the button up.
Something I have never had to do on the Auris but to reset you normally wind full down, then wind up but hold the button up for 30 seconds after it reaches the top.
If that doesn't work then I would suggest disconnecting Battery for a few minutes to reset everything but you will have to do the above then.
If that doesn't work then I would suggest disconnecting battery for a few minutes to reset everything but you will have to do the above then.
Hi Mooly,
thanks for the info, it worked!!
Thanks again.
Have a good Xmas
Paul
