Yaris Rattlig
ptg1174
hi guys my wifes 99 1.0 vvti seems to be rattling when she starts to accelerate then it disappears as speed builds up
any ideas would be great
hi mate
it might be cos of over fueling or bad quality of petrol.
Cheers/Igor
Might just be the fittings.
Since the cold weather, my Yaris has developed two really annoying rattles;
One at idle (8-900rpm) which seems to be coming from the bonnet (I suspect I need to re-apply the electrical tape I stuck on the bonnet catch to fix this last time)
and another even more annoying one that happens at 1100rpm which it turns out is the rpm I tend to be in the most when driving through town!
It is coming from somewhere under the passenger-side speaker so I will probably have to find a volunteer to look under there/under the glove box...
Can you pinpoint where the rattle is coming from? Is it an rattle from the engine, the drive train or are you talking about a trim rattle?
Does it happen when the engine is hot or cold or both?
sorry took so long to reply lost internet connection anyway i have figured out that it is a pulley its the one just above the alternator think its the waterpump am i right or wrong
if you look at the engine over the driver side wing, the pulleys are configured like this on a 1.0vvti, assuming no air con:
Imagine you are looking at a clock
Position 12 o'clock is the water pump pulley
Position 9 o'clock is the alternator pulley
Position 5 o'clock is the crankshaft pulley
Hope the attached rough diagram makes sense! :thumbsup:
post-101289-0-69439800-1294418418_thumb.
If it's the water pump bearing, best to get the water pump replaced as it will leak and eventually fail altogether. You also shouldn't put WD40 near the belt as it will cause slipping
