Radio Fuse?
GazFish
Hi guys,
I've been fitting a Motorola bluetooth Kit to a 2006 Auris. I tested the kit, all was working so I replaced the radio etc. and no nothing? :o(
I've tested the radio without the bluetooth kit harness and there no power to it.
Is there a fuse for the radio somewhere?
Gareth
Many radio systems have a fuse located on the back of the unit itself but also there will be a fuse to the stereo in the fusebox too. It protects (In the Yaris) other stuff too so has anything else gone off? In my Yaris, the first thing you notice is the interior light not working. Also, the clock among other things. Ther should be a fuse rated 15 amps, if I remember rightly to protect these things and they do blow quite easily if you try to connect/disconnect things clumsily, with the circuit live.
...Is there a fuse for the radio somewhere? ...
yes, there is a fuse located in a fuse box under the dash, is fuse no.8 (ACC), 7.5A
