Clock In Blade
barrymem
Moved from the Yaris forum...
The Blade is similar to our Auris so i'm sure one of the Auris lot will be able to help thumbsup.gif
assuming they are the same its easy. first you have to stopped otherwise the system won't let you do this and will cancel it if the car start to move. just press the display button several times until you visualize the "SETUP" option. Once there press and do not let it go until you enter the sub-menu. you should have several options there like "DATE" and another for "CLOCK". to navigate keep pressing to enter one press and do not let go. When you enter the CLOCK menu you should be able to set the hours. Once you're done press and do not let go to set the minutes after that he will exit each submenu automatically after a few seconds or if you put the car in motion.
hope it helps
