Hi guys,
Does anybody know if this can be done? If a 1CD engine from an Avensis will fit a Previa? And if it needs modifications.
Cheers.
I assume you are talking of a Previa built after 2000?
Yes it's a 2003 Previa.
Cheers
  • 1 year later...
yes this can be done i have fitted 2 previas 1 with a 2005 corolla d4d engine and the other with 2004 avensis d4d engine.
there 4 modifictions to do
1: the crank shaft sensor plug is different design to previa and in different position . just extend the wire on the original plug.
2; the injecter pumps are different , this means changing the water pump to house the original previa injecter pump.
3: avensis and corolla use 2 pin injecters and the previa uses 4 pin injecters , these can easily be changed over
4: this 1 is a bit tricky , you have to drill a hole in the block for the engine mounting under the alternater.
both of my previas are 2002 d4d and are still running today, it is posible because i have done them!
  • 3 years later...
I have been told that if you swap the avensis engine for a previa one the previa has alot of engine vibration is this true?
