Mr2 Issues
Hi i brought a 2001 MR2 about 6 weeks ago and now having issues! it is a semi auto so electric clutch and gears on wheel but still has the shift stick anyway when i stop at a junction it wont set off in 1st gear i have to put it into 2nd to get going, and the shift stick is very stiff so have i got a clutch problem? gear box problem? or electrical problem? also can you patch up a radiator? and the calipers toyota say i have one caliper resting on the wheel but they dont know which one and one garage saying the calipers are fine unless i hear a constant sqealing then not to worry! do you think toyota garages are ripping me off there!
please help regarding the gears??
thanks
emma
The calipers sometimes do stick or bind....you would know that if your pulling when you break (like locking up a front) and your know cos your wheels etc will be seriously hot, just take it to a normal place like a one stop and get them to do a FREE thats FREE break test you dont pay for that.
Radiator
you can get radweld and something similer that basically plugs a hole, but that does depend on the size of the hole, always ask someone in the shop and read the packet to see if its ok to do that on your car, its the cheaper option than a complete new radiator...even if it doesnt solve the problem, atleast youve only spent a fiver.
Your gears i wish i cld help but i cant but as u said it would either be 1 or the other gear box or clutch,
