Crank Pulley Camry 90
Jay305
Hi, I've a Camry 90 with a 2L automatic, I've a leak from the crank seal. I removed the pulley for alternator and power steering, the I removed the platic covers. I also removed the timing belt, but now I don't know how to remove the pulley for the timing belt. Does anyone know if I need a special tool, because there is no hole in the pulley neither place to put the legs of a puller. Please help me..
Do you have the crankshaft pulley bolt removed yet?
the crank cambelt pulley normally has two M8 tapped holes in it - so you can "jack the pulley off" :eek:
You have to be carefull,as you will be jacking against the oil pump housing !!
