Celica Gt4 Or Celica Gt4 Conversion?
pentathlete5
Im new to this site.
Im wondering if i can find any gt4 or all trac around where i live (Boston, Massachusetts) or will it be easier to just convert a normal celica to a gt4.
If it is possible to convert Will it even work because i dont know if the st205 gt4 came wide body, so if i take everything from a gt4 (for example) will it fit a gt liftback of the same model year. Because then i can just do that find all the exterior pieces buy the motor, tranny etc. and just put it into a gt liftback.
Comment Please.
Hi, all the information that you require can be found in fine deep detail on www.6gc.net
In short, making a ST202 like a ST205 is relatively easy.
Droping aa ST205 engine into a ST202 is easy too, with std power the GT manual gearbox will be ok, a tuned 3SGTE will require a MR2 box conversion with relative driveshafts.
Making a ST202 into a 4WD requires a lot of cutting and welding of the rear floor.
Join the 6gc club - every aspect of this conversion is there.
The RAV4 manual box also copes with the 3sgte giving you 4 wheel drive too.
  • Topics
  • Our picks
        • Like
        • Like
        • Thanks
        • Like
