Pic* Ts Engine Bay
ts507r
hi, guys, i'm from panama, panama city (Latin America)
here i'm showing my baby...
Toyota Corolla TS 2002
2zzge with Injen CAI (with heat insulator)
Custom Ground Kit
Clutch ACT XTreme Pressure plates and Disc
JUN light-weight flywheel
TRD quickshift set
here is my engine bay:
Here is the 2nd nationals of DRAG in Panama, Corolla TS vs MR2 '89
thanks
my best ET time was 15.30secs.
with a very bad R/T .800
:lol::lol:
i have to achieve the R/T
but it was COOL!!
thanks again
hi dude
nice time and nice car
the TRD quick shift set is also named SHORT SHIFTER....you change the gears more short, easy and fast...it make a good feel when you change the gears.
cost $250.00USD
made by TRD Japan.
the JUN lightweight flywheel or other lightweight flywheel make you revs more faster than stock, i feel a great diference then you push all the gas pedal as 3,000-5,000rpm, you can see how fast is revs your rpms......=)
i'll recomendend!!
installing a lightweight flywheel will make you stall easily, so if you are a daily driving you will be launching a 2,000rpm minimum to prevent stall....
thanks!!
