Door Card Removal
mrrayy
the electric window on the drivers side of my mk2 do not work although they do when they are in the mood sounds like a loose conection,the trouble im having is how to remove the door cards,i can get everything off but the door handle,the one you pull to open,there is one screw in this but when i take this out the handle does not want to shift anywhere,any help would b great,i can find how to take appart everyother door card but not the 2nd gen surf please help.......cheers
job done........easy when u know how, the handle slides slightly then off it comes
