Loud Knocking From Drive Rav4 2.0 Auto1995 120.000 Miles Anyone Got An
RAYKARL
it sounds like its coming from gearbox area but there are no problems with gearbox its worst when turning right i have owned the car for 12 years its the only problem i have had anyone know this problem thanks raykarl
Hi and welcome to the forum.
Maybe a bad wheel bearing ?
Best to post in the RAV section so I'll ask a moderator to shift it to there.
Well as Bothy says, maybe a bearing but could also be a tooth off the diff or a CV joint. It could also be something loose and I would start by getting it on a wheel free lift and turning the wheels by hand while you get up close and listen underneath.
....and if you're stuck for a wheel free lift, bring it up here and park it near Bothy's house.
It will be lifted in minutes and free of its wheels in no time.
Big Kev :thumbsup: HAPPY NEW YEAR ONE AND ALL :yahoo:
Oooh, the wheel bearing is the one issue I have had with my car. Damn I told a fib in my newbie introduction. I was going to say the wheel bearing but mine made an awful grinding noise. I did have a slight tapping sound once, often appeared when going around roundabouts or putting foot on the gas a bit, but it was apparently a rusty jubilee clip for the exhaust which was replaced free of charge.
The front wheel bearing on these do wear out.
Another is the central propshaft bearing - if worn could give a knock but I don't think it would matter what corner you take... when did it pass its MOT last?
