Carina E Wing Mirror Fitting
Please help! Does anyone know how to fit an electric & heated offside door wing mirror to my Toyota Carina E CDX Auto (1997)?
Any help would be very greatly appreciated.
If its the entire mirror then remove door card. Remove surround from door handle undo the screw. remove the screw from the door handle pocket. Remove speaker cover then remove the bolts. Prize the card away from the bottom and sides and then lift up and off, there wiil be wires for your mirror, unclip these then remove the triangular plastic mirror cover. You will see three, i think their 8mm bolts, remove these and your mirror will be off.
