Setting Up Clock
RahulM
I am trying to set up clock and its very difficult..
Can some one please give me steps on how to set up clock on dash board?
You don't say which year or model your car is. From the mk2 manual:
The digital clock indicates the time.
To adjust the clock, put the key in the
“ON” position.
With tachometer
Pushing the reset knob flashes the indicator
for the hour and you can adjust the
hour.
Press the reset knob until the desired
hour will appear.
After 5 or more seconds pass without operating,
the indicator for the minute
flashes. Then you can adjust the minute.
minute will appear.
After 5 or more seconds passes without
operating, the indicator will return to the
normal display.
If the electrical power source has been
disconnected from the clock, the time display
will automatically be set to 1:00 (one
o’clock).
Without tachometer
for the minute and you can adjust the
minute.
minute will appear.
the indicator for the hour flashes.
Then you can adjust the hour.
hour will appear.
normal display.
o’clock)
Thanks Hartside, Raeman.
Mine is 2006 model.
The catch is to get display show outside temperature only then one could set clock.
Should tell you in the owners manual if you have one. :thumbsup:
