1999 Avensis 2.0 3S-Fe Won't Start.
AvensisT22
Hi guys,
This is the problem I have, I removed the intake manifold off my car in order to drill and tap the holes for my LPG nozzles...
Problem now is I can't get the car started...
I removed the injector rail and it was very difficult to fit again with the LPG injector pipes on, as I've got the nozzles as close to the petrol injectors as possible.
I finally got them back on, new o-rings and grommets, no leaks...
I've put all the Vaccuum pipes back on where I think they at least go... and tried a few combinations...
The car will fire and run for a second before dying.. Vaccum leak or flooded engine?
The LPG injector pipes are connected to the rail, so it should start and run and the injectors are off as thus closed. I even took off the pipes and placed a screw in
New development...
Car has started running... must of been flooded... left with spark plugs out and tried to start...
It starts... but it revs itself to 5k-6k before either staying there or stalling...
Massive Air leak I'd imagine...
