Help Needed
cmw1983
2001 Celica
Got 2 fault codes coming up
P0300 - Multible cylinder misfire
P0303 - Cylinder 3 misfire
I've tried swapping the plugs and coils over but it is still coming up as Cylinder 3 so don't think its either of those, Has anyone had anything similer or got any ideas what it can be or is likely to be
Much appriciated
Having done a search I've found out the following - hope this helps
A code P0303 may mean that one or more of the following has happened:
Faulty spark plug or wire - Faulty coil - Faulty oxygen sensor- Faulty fuel injector - Burned exhaust valve
Faulty catalytic converter - Running out of fuel - Poor compression - Defective computer
A code P0300 may mean that one or more of the following has happened:
Faulty spark plugs or wires - Faulty coil - Faulty oxygen sensor - Faulty fuel injector - Burned exhaust valve
Faulty catalytic converter - Stuck/blocked EGR valve / passages - Faulty camshaft position sensor - defective computer
If there are no symptoms, the simplest thing to do is to reset the code and see if it comes back.
If there are symptoms such as the engine is stumbling or hesitating, check all wiring and connectors that lead to the cylinders (i.e. spark plugs). Depending on how long the ignition components have been in the car, it may be a good idea to replace them as part of your regular maintenance schedule. I would suggest spark plugs, spark plug wires, distributor cap, and rotor (if applicable). Otherwise, check the coils (a.k.a. coil packs). In some cases, the catalytic converter has gone bad. If you smell rotten eggs in the exhaust, your cat converter needs to be replaced. I've also heard in other cases the problems were faulty fuel injectors.
Had similar on mine and it turned out to be the injector, pop the plug to it (the injector not the spark plug) and see if it makes a difference, I also used the old fashioned method of using a long screwdriver like a stethoscope and couldn't hear it ticking like the others ;)
