Auris Wheel Spacers
nik sr
Are you planning to just fit spacers, or are you going to lower it too?
Its just personal opinion, but spacers seem to work best when the wheel arches are a few mm off the tyres, and as the Auris sits a bit high as standard, it may look more like a Hilux?
Moved to Auris Forum :thumbsup:
5/6mm won't give you a visible difference in its footprint, go for a Hubcentric Spacers Kit, you get extended bolts etc and you can go all the way to 25mm each side!
I agree with Dave though, if its not lowered (even just 30mm) it will look like the Lara Croft Land Rovers you see driving round (i.e. rediculous!)
Just my opinion of course :D
EDIT: Just found these from Eibach - 35mm! http://www.larkspeed.com/index.pl?a=i&k=s&p=SP99S90435004
