Electrical Problem
myfirstride
I'm a mostly DIYer having elec. problem with my '91 Corolla LS. First I noticed that my taillights were out (found blown fuse and replaced). However, when I switch on dash lights, they come on for only a fraction of a second, then taillight fuse blows. If I watch the clock while switching on dash lights, it dims at same time but reverts when taillight fuse blows. I'm no expert but this suggests to me that a control relay is not working properly. Funny because I had the relay checked at Dealership and they said its ok. (At least what I think is taillight relay - left kick panel near defogger relay).
Other dash lights such as oil, and check engine lights, clock and radio lights work properly. Only dash and console illumination doesn't work. Could the switch arm be broken? If anyone recognizes this problem or has advice on how to determine which elec. component is faulty, please reply. Electrical problems and Dealerships scare me.
  • 5 months later...
hey there,
did u find a solution to ur prob.. i seem to be havin the same thing.. well not tried the fuse yet but i have NO rear lights and no dash but all the lindicators etc work fine. :help::help::help::help:
this happened to my corolla gti last tym
when i switched on the lights the back lights blew
radio and oil lights etc worked too...
i found that the problem was that my brake light bulb only had one fuse in it.....
you have too make sure you got 2 fuse bulbs or it breaks the circuit
hey guys.
this problem can occur if you have had the under dash off (under the steering column) and forgot to put connector back on to the dimmer switch.
rear lights and dash illumination go through this circuit
  • 2 months later...
hey guys.
Thanks luckyy. Problem started after installing new speedo cable... yagga twiny I will try yer advice too.
Do you not mean filaments? bulbs don't have fuses??? Well none I know of :unsure:
Some rear bulbs act as both regular rear lighting and brake indication. On some newer cars you'll find two bulbs one solely for rear lighting and another for braking.
