Inlet Manifold Gasket Replacement
dstephenson96
Hi all,
this week i need to change my inlet manifold gasket on my avensis diesel 1998 2.0.
can anyone tell me if this is a difficult job for a novice, i have tried to find a haynes manual for the diesel model to help but i can't.
i have changed the rocker cover gasket on this before, an oil filter and oil change and a fuel filter change, that is about the extent of my knowledge on this car, so i am not sure if anything is going to stop me doing the manifold gasket.
any help or ideas please
dan
Hi Dan, the problem with a 12 - 13 year old inlet manifold is not so much the complexity of the job but more the issues that arise due to the age of the car. Nuts tend to round, studs tend to snap, gaskets are a swine to clean off and electrical contacts can fail due to corrosion etc. If you have a good tool kit, plenty of space and time to work in it might be worth giving it a go. The manifold is a whole level higher than the jobs you have described. I wouldn't tackle it unless you are sure you can complete it.
Incidentally why does the gasket need changing?
  • Topics
  • Our picks
        • Like
        • Thanks
        • Like
