Fuel Flap Stuck
ali1605
Wonder if anyone can help, the fuel flap on my celica wont open, I have a st202 import, can you get to the fuel flap though the boot?
If anyone can help that would be great, Many thanks Alison.
Is it the cable is not releasing or the flap isn't poping out when the level is pulled?
Hi dont know if its the cable or the spring on the flap, going to have a good look today, just a pain when you really need fuel, felt a right blank when I couldnt open it at the pump and then had to drive away lol, bet other drivers looked at me and thought there goes a typical female lol,
Gawd! My nightmare, and has been since they stopped putting keyholes on filler caps!!!
Hope you get it sorted :thumbsup:
You'll need someone to help, pull the level while your friend tries to open the door, if that works you've lost the little spring clip that makes the flap pop.
If the flap can't be opened it's your cable somewhere that's at fault, I'm not sure if they have any adjustment on them
