Any Point In Using V Power Diesel Over Ordinary Diesel?
bazzablue
Hello! I have a Yaris 58 plate D4D and have been putting only V Power diesel in it for the last 12 months. Am I wasting my money?
Yep - probably.
I've tried the V-Power diesel in my A3 for a few months at a time on several occasions over the past five years. Compared to "ordinary" Shell at the time, it did give slightly better mpg but not enough to cover the extra cost.
I still put a tankful through now and then because its got better cleaning agents, so I assume it will give the injectors a good clean through.
Before Shell changed their standard fuel recently, you could tell a difference when you put the vPower in - it ran a bit unevenly until the ECU adjusted for the different fuel, so it was definately different - however since Shell changed their standard fuel, I now notice no difference when I switch fuels (so I've half a suspecion that the differences are now less than they were) and actually, I got less MPG on my last tank of V Power than I get with the new standard Shell diesel.
So I won't be going out of my way to buy VPower diesel any more - I'll stick with the new standard shell product...
I have never found it any better when the temps are low to be honest.
Might be better in the spring/summer months though....
Made zero difference to my Yaris...
Made the engine run smoother, loss of torque/power at low revs but you get it all back at higher revs.
RAV4Len is right that the difference vs. normal diesel is a lot less noticeable in winter tho'.
I will say that if you have been using it constantly, your engine will be much cleaner than ours! :lol:
Supposedly it also helps reduce the likelihood of EGR problems, esp. if you're doing lots of town driving and not much motorway driving.
My main turnoff used to be that V-Power would push me over that £50/tank mark but, strangely, since a normal tank will now be more than that, I think I'll care less now! (In reality it's only a few quid more anyway...!)
I used to put this into my diesel Alfa:
http://www.halfords.com/webapp/wcs/stores/servlet/product_storeId_10001_catalogId_10151_productId_370465_langId_-1_categoryId_165750
I found it gave a much more noticeable improvement in smoothness and response. Also kept the EGR valve in tip top condition
Thanks for the replies! I'll take the info on board for next time I need to fill up!
Im new to this site and am just finding my feet on it. Its good to know that there is somewhere I can come to when Ive got an issue and need advice.
Am really pleased with my Yaris - had it for 12 months now. I exchanged it for a 2.8 Vectra Elite which did the grand total of 16 miles to the gallon and am now getting 52 miles around town - bit of a difference!
'tis a lovely car :D
Glad I listened to my mate and went for the diesel one too; So cheap to run but still pulls when I want it to!
Never would have believed a diesel engined car could be this good until I got mine! :thumbsup:
Now if only they made a diesel-electric hybrid version... ;)
That will never happen because it would spin the world on its axis :)
